Maria Irina
BUG AC28-2026-03-26-09-22-28-4008
I got this bug and i do not know what to do and what is causing it. I have a licensed eductional version of archicad and i have worked on this file for a few months and since last night I cannot work in it anymore cause a few moments after i open it it gives me this bug and shuts down. Can anyone help me with some advice on what can the problem be?
CosminF
Can you open a new empty Archicad? If so, you can try and go to file - open and from open your bugged file (while making sure to check Open and repair). That might fix it.
Also, you might want to take a look here: https://support.graphisoft.com/hc/en-us/articles/26373405770129-Archicad-crashes-before-startup-or-s...
To check the status of the bug (based on the bug-id), Archicad recommends to check with your local reseller:
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
