BUG: Complex Profile Add/Remove Fill Outline;Does Not Stay!
Can some one check if Complex Profile Add/Remove Fill Outline Stays on after Remove it, Store the profile and select the fill & Settings. It reverts back to Add outline & pen #1. Even with Hotfix #1 it is still doing it.
Thanks
2 REPLIES 2
Same as your experience, I can not remove a fill outline.
Even creating a duplicate and removing the outline = no go.
In what version of AC have you successfully removed the fill outline?
If it is pen #1 you find offensive... Replace outline with the
DOT line, or create an even less dense dotted line and then
create a 01mm pen in white or something along those lines.
Snap
Thanks,
I reported the Bug and it is one. We weight for the next hot fix.
