2007-08-01 10:07 AM
2007-08-01 10:27 AM
2007-08-01 10:54 AM
2007-08-01 02:00 PM
2007-08-01 05:12 PM
Karl wrote:Every so often there are changes in the program dramatic enough to make it very difficult if not impossible to maintain backward compatibility. This happened with the transition from 3 to 4 as I recall. Even library parts had to be converted to run on the new version, and AC5 would not open AC3 files.
Try opening that with only V11 installed on your machine and tell me you don't have a problem.
2007-08-01 07:55 PM
Karl wrote:I sympathize with this one, but like so many things, would rather see GS spend their limited resources on other matters (bug fixes and beyond).
We can open AutoCAD files from within ArchiCAD V11 back to those produced pre 1990, but not native ArchiCAD files back beyond 2003?
How many different versions of the software do you intend to have installed in 10 years time? Never mind the different library versions we will now have to collect on an annual basis? I guess most people are not bothered by this but what of the hassle of revisiting old projects say something done in 2000 V6.5. Try opening that with only V11 installed on your machine and tell me you don't have a problem.
2007-08-01 09:23 PM
Karl wrote:...and keep at least one old computer & OS around (G4-G5 + OSX Tiger, P4-PentiumD-Xeon etc. + XP-SP2 or such) that runs AC/PM 9 properly. It runs OK on Intel Macs, but I wouldn't count on that remaining true, and I don't think it is Vista compatible.
PS As Matthew says, 9 is a good version to keep around, as it can save back to version 6.0.
2007-08-02 09:28 PM
2007-08-03 07:54 AM
2007-08-03 08:22 AM
Philippe wrote:If You have the 7.0 CD You could actuallly find a 6.5 working with WIBU there...so no need to be on the dark side
I did not install AC11 yet but the documentation says you can use the dongle back to 7.0 installation.
Actually, we have kept a 6.5 "open source" version, which allows us to get our oldest projects (5). I think GS could distribute a free AC 6.5 CD, so we do not have to use the dark side way…Who's going to professionally use a 6 years old soft?
