Balustrades and guardrails
With Archicad V10 there I can't find a tool/way to model guardrails or balustrades at interior floor openings or facade balcony edges. Stair tool is the only reference I can find related to creating balustrades. Does anyone have a tip? Thanks.
3 Replies 3
Try the object library: (Building Structure - fences and railings)
There should be some parametric railing objects there that you could use.
you could use Trussmaker if it suits your requirements:
http://www.graphisoft.com/support/archicad/archiguide/techtipsept2002.html
I heard some folks can use the curtain wall tool (but thats only in AC12).
