Stress Co_
Be carefull how you draw it.........
Just what you don't want to see at a site inspection .......
Marc Corney, Architect
Red Canoe Architecture, P. A.
17 Replies 17
Now that is an incompetent contractor!
Dwight
While it is funny to think that a bubble connector line could be made into a stair tread, how do you think they did it and still matched the height and number of risers?
Dwight Atkinson
Stress Co_
Simple..... 4-1/2" Risers
Dwight
Precisely!
You can forgive a builder for mistaking a line for an edge, but not for sitting down and recalcualting the stair.
Dwight Atkinson
Aussie John
The ironic thing is the guy doing the work was probably muttering to himself about what a dumb @@ the Architect is!!
An old boss once told me he arrived on site to find all the windows with diagonal glazing bars which matched the hinge/opening chevron on the drawings
Cheers John
[/size]
Dwight
This is a good example of bad graphics - double checks of the riser math aside - it is like an optical illusion: once the diagonal is seen in the mind as a step, it is impossible to eradicate.
Sometimes i think the drafting board was a safer place to work because bad overlaid graphics like this could never happen. Almost never. There was the time a coffee ring on my drawing was built as a spiral stair, but that should have been easy to catch.
Dwight Atkinson
Stress Co_
I once had a project with a concrete walkway that had a scored-gridline layout.
A dimension string's leader line crossed the walkway.....and you guessed it....... They scored it in the conc.
One oblique line bisecting the grid.
This was on a drafting board
Dwight
This explains your avatar, then.
Dwight Atkinson
KeesW
I once drew a wobbly line to indicate a craftwood panel behind a reception desk to find it built on site. The builder had made a full size template of my scribble and cut it out with a jig-saw. Funny thing was - it looked OK!
Cornelis (Kees) Wegman
cornelis wegman architects
