Beam Corners are not mending in 2D, Why?
4hotshoes
I have never seen the beam tool not mend corners and intersections. Is there a setting that controls this? See image. They mend fine in 3D.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
Have a look at the layer Intersection Priority number (in the layer settings) of the layer that the beams are in.
Is it set to 0 (zero)?
If so the beams will not trim.
It could be that you are using a different layer combination in plan and 3D - the IP number for each layer is saved with the layer combination.
David Maudlin
Todd:
Also check your On-Screen Display Options > Clean Wall & Beam Intersections.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
