Beam display problem
hello there!
i have a problem with my beams. i draw them in floor plan and i want them to have a dashed line but they have continuous! why is that? in ac9 they always had dashed.
what's this option about outlines and overhead outlines? i still dont get it
thanks
Rod Jurich
WENDY_NEVERLAND wrote:
/.....i still dont get it
Would this help, Vivi.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
thanks
the overhead lines are the lines that indicate the part of the beam which is above the floor plan cut plane. - Look in Help menu and enter a search for overhead lines.
i found it!
it had to do with the floor plan display i had the outlines only and it had to be the projected with overhead!
thanks
