Yes you can bring in a hotlink as many times as you like.
If you change the original all hotlinks will update.
You can break the hotlink if you need to modify an individual plan but I would create a new duplicate PLN and modify that then link that one in.
Mirroring shouldn't be a problem but it may depend on whether you left justify or centre justify your text and labels.
I centre justify everything and that remains the same when mirroring.
Left justified will become right justified however.
If it doesn't work then just duplicate the original plan and mirror that and fix it up - then hotlink that in.
Barry
