Mahicol
Black Dots in Archicad
Necesito ayuda, si alguien puede indicarme como solucionar este inconveniente.
me aparecieron bolas negras en el diseño y no se donde o como se configura eso.
ya desinstale el programa pensando en que se podría solucionar pero no.
Translation - I have only done this because it already has a reply that was correct.
Please remember to post in English only.
I need help, if someone can tell me how to solve this problem.
Black balls appeared in the design and I don't know where or how that is configured.
I already uninstalled the program thinking that it could be solved but no.
1 Solution
Hello Mahicol,
Here you should write your request in english
It is not my birth language too.
I see black points which means that your should check your library links.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Go to post
Hello Mahicol,
Christophe - FRANCE
Archicad 15 to 29
Mahicol
Christophe
I managed to solve, update the library that were missing. It was a miracle because I had a problem with my album and I lost the latest updates.
It was already solved and it was because of the bookstores, thank you
Greetings from Uruguay
