Blue flat staircase
Hello. Please help a noob. My stairs are blue and flat. It used to be normal, but I clicked on something and everything broke. Now I don’t know how to make the stairs normal again.
1 Solution
"Document > Model View > Model View Options" menu command.
It is also accessible from the Options Bar at the bottom of you ARCHICAD Window by clicking on its icon:
Go to post
4 Replies 4
This happens when you set the "Stair 3D and Section/Elevation" field to "Schematic" in the Model View Options Dialog.
Set it to "Full" and the Stair will be displayed properly.
Model View Options Combinations (the list on the left pane of the Model View Options Dialog) are saved with Views so it can change again if you activate/restore a View which is saved with a Model View Options Combination in which this field is set to"Schematic".
I can not find Model View Options Dialog
I have done it. Thanks you
