2017-06-09
03:17 AM
- last edited on
2023-05-26
11:13 AM
by
Rubia Torres
2017-06-09 02:31 PM
Jeanie wrote:Go to Work Environment > Command Layout Schemes > Menus. In the right panel navigate to the Attributes submenu, then select the Building Materials... command in the center panel and drag it to the right panel. Then select Command Layout Schemes in the left panel and Store As.. this set up and make it part of your Default Work Environment. For more information see in the Help Files: User Interface Reference > Dialog Boxes > Work Environment Dialog Box.
1. I am trying to add Building Materials to my >Options >Attributes. I can't seem to pull it together. I can see how to bring other Attributes in thru the Work Environment >Toobars>Options, etc.
Can someone give me a quick path to getting it into Options?
My friend has AC19 and I see it in his Options but it has always been missing in mine.
