‎2004-09-24 10:15 PM
‎2004-09-25 03:05 AM
Currently, ArchiCAD has no guarantee of model accuracy, since it does not enforce the user to create the model in a specific way. Modeling errors—and there could be many of these—will have to be detected by external applicationsIs it true that the model may not be accurate, and therefore the CD's are not accurate?
‎2004-09-25 03:22 AM
‎2004-09-25 04:38 AM
‎2004-09-25 05:33 AM
Scott wrote:It is possible to model elements badly, just as it is in any other CAD program. ArchiCAD does do a good job of making it graphically obvious when this happens as long as one maintains high quality standards.
‎2004-09-25 07:26 AM
Matthew wrote:There is such a thing. Solibri model checker.
I believe what was meant is that there are no built in collision detection tools and things of that sort. This can be done as a post process in Naviworks if I recall correctly. It would be nice to have things like collision detection and code checking as optional add ons to work interactively.
‎2004-09-25 10:41 AM
Scott wrote:We encountered this problem developing the GBS Energy add-on. The software tries to discover where the building spaces are by analysing the model, but it won't succeed if there are gaps between walls which 'leak' the spaces into each other or to the exterior. However, we do give the user the option to clean up or extend the work done by the software to overcome this issue. If the user produces a model with full closure, the software will fill all the spaces Zones with with no assistance.
What does the author mean by this?Currently, ArchiCAD has no guarantee of model accuracy, since it does not enforce the user to create the model in a specific way. Modeling errors—and there could be many of these—will have to be detected by external applicationsIs it true that the model may not be accurate, and therefore the CD's are not accurate?
‎2004-09-25 02:22 PM
Djordje wrote:It works interactively? I thought it was a post process, i.e. output model, run check, return to AC to fix.Matthew wrote:There is such a thing. Solibri model checker.
‎2004-09-26 02:51 AM
‎2004-09-26 03:00 AM
