2026-01-20 12:54 AM
having a slight problem. When you hover your cursor over and object, a little tag usually shows up that tells you what it is. Mine is not showing up Probably just a button that's pushed. Any ideas?
Solved! Go to Solution.
2026-01-21 02:02 AM - edited 2026-01-21 02:04 AM
Help => Show Tool Tips
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2026-01-20 01:16 AM
In your Work Environment, you want to 'enable element info tag'.
2026-01-20 06:42 PM
Kind of works. It works in the work field (main screen), but not in the Design bar
2026-01-21 01:35 AM
What is the Design Bar?
2026-01-21 10:47 PM
On my computer, it's the command bar on the left of the screen, containing the design, viewpoint, and document commands
2026-01-22 01:20 AM
Ah, that is the 'Tool Box' palette.
As Ling suggested, 'Show tooltips' will show info for this and all other tool bars.
2026-01-22 08:12 PM
I've got an old Archicad 16 manual, and it's not called out anywhere. I wasn't sure what to call it. I had to take a year and a half off to get my leg amputated, So I need to catch up as to what things are called
