CURTAIN WALL CUSTOM ALIGNING ISSUES
Is there any fix. I already tried to aligning the curtain wall by editing the grid scheme but the points just won't stay. It needs to be just like the images below. Thanks
1 Solution
Carstenem
You went the right way about it but you need to have 3 parts to make it fit. See screen shot.
- Start with part 1 between the 4 columns. As you mentioned just increase the width in the scheme until it fits between the first 2 columns. ( divided by 5 in this example )
- then draw part 2 + 3
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Go to post
4 Replies 4
Carstenem
Carsten
www.asmtechbase.com
Carstenem wrote:
You went the right way about it but you need to have 3 parts to make it fit. See screenshot.
ok. So I draw 3 parts as you said. How can we join these part as a whole? Because there are frames overlapping.
Guru
Could you just delete them using the edit function?
Ling.
Carstenem
Yes Ling is right just use edit in 3D and delete the double frames
Carsten
www.asmtechbase.com
