Cabinets change their orientation
Whenever I change some of the parameters of the cabinet library parts (ACAD 16) their orientations change. This is very annoying. Do I have to reset every time I make a change?
Thanks for the help.
2 REPLIES 2
Are you by chance rotating the preview of the cabinet so you can see what happens when you change your parameters?
If so that is why the cabinet orientaion is changing.
Changing a parameter shouldn't alter the orientation (unless it is a rotation parameter).
Yes. That must be it. I wish ArchiCAD wouldn't do that. I'll have to deal with it.
Thanks so much.
