Calculate-List Fills and Objects. How it works?
Hi!
How it works? Somebody knows?
The List Fills and Objects popup menu allows you to list Fills and Objects that are included in Floor Plans, Sections, or both. The Select Sections subdialog lets you specify particular Sections to list from.
I have not tried it just now, but for me it says you can select from which Window you want Fills to be included in the List. E.g. if you check Floor Plan, Fills placed in the Floor Plan and their selected parameters will be listed. Fills placed on any section/Elevation will not be included in the list.
Or you can say you want Fills on Floor Plans, plus on certain elevations to be included in the list.
Laszlo
Thank you. I have understood, this works only if fills and objects are created in Sections.
