LeeJaeYoung
Can Archicad see multiple views on one screen in window 11?
Multiple views on YouTube...
I couldn't find it no matter what
AC27 on window 11
1 Solution
Yes, just the same as with any version of Windows.
Press the maximise/unmaximise button (restore down) to undock the window from the TAB bar.
Then resize and position the window as necessary.
Be aware that only one window will be active.
Make changes in one window, the others do not update until you click in one of them to activate that window.
Go to post
8 Replies 8
LeeJaeYoung
Thank you so much. ^^
Is there a way to sort it?
AC27 on window 11
You mean automatically arrange them?
No, you have to resize each window manually.
LeeJaeYoung
yes
I was just asking how to enchant automatically as in autocad.
1. It is my little wish to have sorting ^^
2. It is my little desire to be able to take display from two monitors to another. ^^ (implemented in Revit)
Have a nice day
AC27 on window 11
LeeJaeYoung
When you click on the 3D view on the plane, the 3D view plays immediately, but
When you return to the plane again, the floor plan, elevation view, etc. all disappear, leaving only a white background. And if you move the screen a little, it will appear.
AC27 on window 11
ryejuan
Acutally I'm also hoping that Graphisoft can manage to like a real time views where you are editing in floor plan then it will be reflect in your 3D views, Section view or Elevation. 😁
WINDOWS 11 PRO
LeeJaeYoung
yes
I wish I could choose as an option.^^
AC27 on window 11
Julio C Freitas
These are simple wishes in my view. In which Graphisoft should pay attention not to fall behind its competitor.
