Can I clip or define spline bounds to a hotlink?
My site topography PLN is separated from my main PLN.
In PlotMaker, on my site plan, I need to somehow "hide" the contour lines from the site plan by using the profile of the roof in the main plan.
I cant see any options for clipping hotlinks, is there a way I can achieve this goal?
Eduardo Rolon
With the fill tool set for "empty fill" or "airspace", Magic Wand the profiles you need.
Then select the fills "cut" and "paste" into the siteplan pln.
If necessary do an "arrange" "bring to front"
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
If the roof plan has a fill with a white background pen you can layer the PMK/Drawing files within Plotmaker (Tools / Display Order /Bring to Front) and it will block out the parts of the site plan under it.
Check that Options / Preferences / Miscellaneous... is set to "Use fills background colour"
Check in the Drawing Settings for your placed roof plan that the frame is "Transparent Background" or the whole frame will block what is behind in the display order
Use hotspots to accurately align the two drawings.
This will work in Plotmaker 2 when you plot as well but the preview on the screen will not show it.
regards
Erika Epstein
2 approaches come to mind.
1. Using Ejrolon & Bills approach but instead of the white pen for the fill, use the white pen for the contour around the fill and the last fill type "-1" (I call it the TV fill as that's what the symbol looks like). It will not print, but take on the color of your screen background, it will mask out what you want.
2. If your contour lines are on a separate layer, turn them off. Open the setting for that placed view.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
