2007-08-08 01:47 PM
2007-08-09 07:56 AM
2007-08-09 08:27 AM
TurboGlider wrote:
Like this?
The last thing you do after you have build your wall and the too roof is :
Open 3d view
Select wall
Rightclick
Use Trim to roof
(If you use SEO instead of Trim to roof, you have to put your cuttingroof in a layer that you hide. If you use Trim to roof you could erase this roof if you don't need it anymore.)
2007-08-09 08:32 AM
2007-08-09 08:45 AM
Link wrote:This method is ofcause to recommend, but than you need some knowledge in GDL.
It is even feasible to do this with an opening. The image attached is just the W Rhombus Opening 11, but if you had your own custom GDL object it would give you much better control both in 3D and in plan.
Link.
2007-08-09 08:55 AM
~/archiben wrote:I'll search for that too, maybe it could be useful sometimes...
i seem to recall seeing an 'Angled Wall End' object kicking around at some point. it's not in the standard library and i can't remember where i saw it.
TurboGlider wrote:Yes, that's right way - I made it
Open 3d view
Select wall
Rightclick
Use Trim to roof
2007-08-09 09:53 AM
TurboGlider wrote:Well of course - or you could get someone to make it for you. The benefit is that you have one simple placement of a single object for each end of the wall, with predictable and stable results. If Scrat needs to model a building like the Burj Al Arab hotel in his avatar, then all those SEO's will simply overload his project.
2007-08-09 03:22 PM
2007-08-10 04:07 AM
2007-08-10 07:40 AM
2007-08-10 09:15 AM
