Too Long
Can MEP ducting be drawn vertically from a horizontal run?
EDIT:
Yes, the height of the duct can be changed whilst drawing it using the arrows in the palette under Construction Method
Can MEP ducting be drawn vertically from a horizontal run so that AC ducting can run under and over beams and other roof members and obstacles?
The below images show the ducting running into a bulkhead, under a beam which it is then required to run into the roof space but as I dont know how to draw ducting vertically it exits through the face of the bulkhead.
AC26 AUS Full
Too Long
edited
AC26 AUS Full
g r a n t
Same question.
I started learning ArchiCAD at age 50....bear with me,
AC29
MacBook Pro M1 Max.
Tahoe 26.5.1
