Can any one tell me why some objects do not show on layout?
I have placed chairs etc on my roof plan and they can be seen. (they are not in a hidden layer) But when I look at them on the layout sheet they are not there and they don't print out.
Thanks for any help given
Deb
vistasp
Have they been placed above the cut-plane by mistake? I sometimes place, say, an overhead cabinet and then forget to change base elevation back to zero for the next object.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Bob Moore
Does your layout sheet layer settings match your work sheets? Sometimes I don't update my layer settings and the layouts aren't what I had intended.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
vistasp
Oops!
Didn't notice that you said "layout". Probably a layer combination.
= v i s t a s p =
bT Square Peg
