2013-08-10
04:00 AM
2023-05-25
05:59 PM
Rubia Torres
2013-08-10 04:11 AM
2013-08-10 09:16 AM
2013-08-16 02:25 AM
2013-08-16 04:31 AM
File formats
EDU and commercial project files will have the same file format (.PLN), but EDU files have an irremovable logo at the top right corner. This logo will be present on all printouts. Because the new EDU file format is the same as the full, the Archicad 10 EDU version are NOT compatible with the previous educational versions and does NOT read (˛.PNE, .PAE ...) files created with earlier educational versions.
Compatibility issues
EDU project files can be opened with a commercial version of Archicad. In this case, Archicad switches to EDU mode. The logo cannot be removed. Commercial project files can be opened with an EDU version of Archicad. In this case the logo is added, and cannot be removed later. Besides 'Open', no other data exchange (copy, paste, merge, hotlink…) is allowed between EDU and commercial project files.
2013-08-16 04:35 AM
Maysum wrote:or you mean that you are running AC12 student, the original file is AC regular and you cannot run the translators since they need a license to run?
Is there any other method to do this? its not working, as im running a student version
2013-08-18 11:08 PM
ejrolon wrote:Ya I am running ArchiCAD AC12 Student, and the files i want to use are AC regular but from a much older Version of AC. Ya will need to find someone with a licence to help me upgrade these files.Maysum wrote:or you mean that you are running AC12 student, the original file is AC regular and you cannot run the translators since they need a license to run?
If so you can get in touch with someone that has a key to bring up the file.
