ā2009-06-16
04:30 PM
ā2023-05-23
03:02 PM
Rubia Torres
ā2009-06-16 09:13 PM
ā2009-06-18 01:32 PM
ā2009-06-18 03:49 PM
ā2009-06-18 10:03 PM
Enrico wrote:
However, when I do in in 2D, for some reason ArchiCAD switches it to the normal roof slab and creates a normal straight slab.
Enrico wrote:
I'm now trying to replace these GDL objects with one wall each, as wide as the relative stair fly. I can shape the top part of these walls to fit the stair fly using the Solid Operation tool (subtract with above extrusion), and I need to create an arch-shaped roof slab to do the same for the bottom part.
Enrico wrote:
This works well in building sections, but I can't get the plan view to cut the GDL objects, so the plan I get is not correct.
ā2009-06-22 06:24 PM
