Can't import AutoCAD solids
I can import AutoCAD dwg files like library parts, but I can't import solid object (it doesn't appear). So when I need something in 3D I have to model it with surfaces in AutoCAD.
I work in AutoCAD2004 and ArchiCAD 8. How to import AutoCAD's solids into ArchiCAD?
1 REPLY 1
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
http://www.graphisoft.com/support/archicad/archiguide/3ddatafromautocad.html
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
