Can't see cut objects in my section
Could somebody help me with this problem.
When I want to create a section I only can see the uncut objects.
Thanks
2 Replies 2
rgarand
Looks to me like you do not have certain layers on. Check your layout settings to be sure you have the layer combination you want as well as the appropriate Model View settings. You may also need to check your section settings.
Don't forget to add a signature to your profile. Helps to know what version of ArchiCAD you are using and the system you are working with.
See mine and others within the forum for signature examples.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
I just read another post talking about when elements go missing ... http://archicad-talk.graphisoft.com/viewtopic.php?t=47548
In it Link mention an option to "Hide Cut Elements".
It took me a while to find it until I realised it is an option in the interior elevation settings (I don't use interior elevations).
But I am guessing you have ticked this option by mistake.
