2009-07-29 02:47 PM
2009-07-29 02:50 PM
2009-07-29 04:14 PM
2009-07-29 04:15 PM
2009-07-29 04:33 PM
2009-07-29 04:41 PM
Steven wrote:Sounds like it! Glad you got it working again.
...I've also noticed while editing a profile, some of the layers cannot get turned on/off. Usually you can turn off the drafting, construction, stretch layers, but in some instances I cannot. I restarted archicad and tried again and it worked. Is this all a bug?????????????
2009-07-29 04:46 PM
2009-07-29 05:55 PM
Steven wrote:There is only one bug that I know of that would affect editing the profile, but not stretching.
It's still not stretching! Maybe I have to redo it... why do I seem to get all these da-mn bugs?
2009-07-29 06:08 PM
Karl wrote:That's probably it, I always have my navigator up.
The bug is that if you have Navigator Preview visible while editing a Complex Profile, that then the stretch lines may disappear and you will lose layer control. Restart ArchiCAD, close Navigator Preview and edit the profile.
Clear any user origin. Select all and drag your entire profile to the true origin as described by Peter.
NOTE: you can only make your wall TALLER, never shorter than the drawn profile. So, generally, don't make the wall as tall as you show it. Make it only as tall as its shortest incarnation - perhaps 3' / 1 meter / whatever.
HTH,
2009-07-29 06:15 PM
Steven wrote:No need to delete. Nothing about the profile itself becomes corrupted. But, you can select all, copy and paste into a new profile if you want to experiment on a fresh copy.
I will try messing around with it some more: probably just delete it and start over (it's not very "complex").
