‎2020-07-08
11:56 PM
‎2023-05-25
05:52 PM
Rubia Torres
‎2020-07-09 12:06 AM
‎2020-07-09 12:19 AM
PS ... ah... from your example, I'm guessing that you want to change the visibility of the given layer in various layer combinations, hence having it pre-selected would save searching for it...?Exactly, not merely changing visibility; it is also simple by quick layers pallet.
‎2020-07-09 03:04 PM
aryastark wrote:Makes sense. In particular, ARCHICAD should be consistent, as you suggested earlier, and if an element is selected, any attribute dialog should open with the corresponding attribute(s) of the element selected. Make a wish with a poll in the User Interface Wishes forum
In addition to, changing layer name; changing it's priority level; duplicate it as a sequel to a close name for a reason; delete it etc.
‎2021-06-10 11:13 PM
‎2021-06-11 05:23 AM
