Can you change the Lanuguge of ArchiCAD
i am from the UK but i am working in Paris for the next three weeks, the version f archicad the office is using in french . i have little experience of archicad and am finding it difficult to understand with it being in french + my french sucks, can you help me!!!
Tim
5 Replies 5
Archicad is not multilingual...but You should be able to install and use the INT version on French key. (It is possible for me to use INT version on a Polish key - but I am not sure if works on French key - give it a try)
Best Regards,
Piotr
It may be tricky. I found that the french version will not work with my US key (which will run the INT version), but the french key may not be restricted. Or maybe everyone can run their own localized version and the INT but not some (or any?) of the other localizations.
Does anyone know the details of this?
Matthew wrote:
It may be tricky. I found that the french version will not work with my US key (which will run the INT version), but the french key may not be restricted.?
I can run ARCHICAD INT with my french key, but not the spanish one.
Til
It begins to seem that everyone can run their own localization and the INT version but not others. Is anyone out there able to run a local version that is not your own?
Rafal SLEK
Try Hungarian 🙂 Polish keyplug works with ArchiCAD 10 Polish, International and Hungarian version. French or German doesn't work as commercial for me.
Gorbie: try to use INT version (You could download it from eduserver) with this French keyplug as Piotr told You.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
