Gunnar
Can you continue an existing spline (add points after the last point)
Is their a way to continue an existing spline (add points after the last point)? I don't want to drag the endpoint or add points on the spline. I want to add points after the last point. Similar to how you can continue a polyline (See attached).
Operating system used: Windows 11 Pro
1 Solution
Ricardo Lopez
Hi @Gunnar
You cannot continue an existing spline as you can continue a polyline but you can create as many splines together as you need and Edit> Reshape> Unify
See the image and video attached.
Ricardo López, M. Arch.
Go to post
Ricardo Lopez
Hi @Gunnar
