ngoldie
Cannot turn any object/line/wall outline into a dashed outli
I'm new to archicad and have been used Archicad 20. I have tried with a lot of different types of objects and even simple straight lines to have them as a dashed line but it always turns out solid. Is there a global parameter somewhere that I'm missing?
Thanks
Ngoldie
Archicad 20
MacBook Pro - laptop
6 Replies 6
Eduardo Rolon
In Project Preferences look under Legacy.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
David Maudlin
Ngoldie:
This could be controlled by the Renovation Filter Options > Graphic Override Rules (now part of Graphic Overrides). In the Help files see: Views of the Virtual Building > Renovation > Renovation Filters. It could also be part of an applied Graphic Override Combination (Views of the Virtual Building > Graphic Overrides > Graphic Override Combinations).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
ngoldie
Thanks for the replies, there were a lot of Graphic Override combinations, I've also added a signature to my profile. I hope the signature is along the lines of what I should have added.
Thanks!
Archicad 20
ngoldie
And a lot of renovation filters
Archicad 20
David Maudlin
You should add your ArchiCAD version and operating system to your Signature.
There should be an option for No Overrides to turn off all the Graphic Overrides.
David
ngoldie
Thanks, just updated my signature to incl my operating system and what version I'm running.
Archicad 20
