Center Door between Two grid lines
Is there an easy way to center a door between two grid lines?
3 REPLIES 3
David Maudlin
trk001:
This is how I would do it:
1. Select the Door.
2. Activate the Drag command
3. Activate the Snap Point Constraint (Snap Points is set to Half)
4. Click on the two grid lines you want the Door centered on (click anywhere on the grid lines, the Door will stay in the Wall)
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Post moved.
Thank you, David! This is exactly what I was looking for.
