Biagio 1777
Elevetion line problems
I don't know why but in every elevation archicad show me those strange lines between the walls-floor intersection.
Anyone can help me?
Thanks!
7 Replies 7
jl_lt
Ace
Hi, there either is:
a) a diference in material
b) the elements are not continuous and not joined
c) there is an error in modeling (even 1cm can cause this)
d) another buggy behaviour
e) all of the above
a and c being the most probable.   best of lucks!
MitchD
It looks like you have story levels shown on your elevations. Check this setting...
ArchiCAD 29 /// Win 11 Pro - Ultra 7 155H - 32GB RAM - RTX 4060 8GB /// Win 11 Pro - i7 12700 - 64GB RAM - RTX 3070 Ti 8GB
Lingwisyer
Guru
Have you published to see if these lines are actually there?
Biagio 1777
I already did it but it doesn't change anything
Biagio 1777
unfortunately, I'm sure they are there 😂😅
Biagio 1777
how can I join the walls with the floors? shouldn't it do this automatically? the material is the same and the modeling is correct
I think it may be a PDF artifact issue as mentioned here ...
https://community.graphisoft.com/t5/Documentation/Visual-Artefacts-when-Publishing-PDFs/m-p/341912
