Chain link fence
Aime
Please where can I get the chain link fence material. Done the search but yet to find the material. Would appreciate any help. Thanks
Have you seen the light?
AC 12, AC14, win 7, Hp pavillion dv6 2.4Ghz, 4gb Ram
5 REPLIES 5
Dennis Lee
There is an object called Treilleges here:
http://archilib.od.pagesperso-orange.fr/index.html
I usually use a simple guardrail object from AC library, and combine it with this object to make it look like a chainlink fence.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
It sounds like you are looking for an alpha-masked photorendering material to apply to a wall surface so that it looks like chainlink in a render (and has almost no polygons)?
If so, the ArchiCAD libraries have a tileable texture called "Fence Chainlink alpha.png" in the "[TImg] Textures <version>" subfolder. (It was a tif in early versions.)
I'm attaching a reduced version of a much better texture image in case that is what you're looking for. (Full file with alpha mask is licensed and huge.)
Or, did you mean an object such as in the link that Dennis provided?
One of the forum moderators
vistasp
There's a bunch of chain link images with alpha mask here:
http://www.filterforge.com/filters/871.html
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
To add on to Aime's question, Are there any Archicad chain link objects and barbed wires within a latest Archicad object library?
