2007-01-29
10:55 PM
2023-05-25
05:57 PM
Rubia Torres
2007-02-01 11:50 PM
2007-02-05 07:36 PM
2007-02-05 11:50 PM
KCW wrote:There's your problem. Selecting from the menu means ArchiCAD doesn't know which corner(s) to chamfer so it will only do all of them. Use the pet palette, select the fillet tool and check the chamfer box.
I am selecting the chamfer tool from the edit>reshape menu
2007-02-06 11:31 PM
KCW wrote:the chamfer dialogue is probably remembering your last setting - as other people have mentioned - but it might be greyed out because you have 'grouping' enabled and the element(s) is/are a part of a group: you cannot make 'reshape' modifications to grouped elements when grouping is enabled. suspend groups and give it another go . . .
And I see the checkbox to deselect the apply to all corners option, that checkbox is selected and "greyed out" or locked in that mode. How do I unlock it?
2007-02-06 11:34 PM
