2024 Technology Preview Program
Change Storey level without moving content
Hello there,
when you have surveyors that gives you wrong Levels at the beginning (or doesn't give them to you at all and you need to guess), it can happen that you need to adjust a storey level but do not want to change where everything contained on that storey is.
Is it possible?
Thank you.
C.
10 REPLIES 10
You could create a new story and then change the Home Story of the desired elements to the new story without changing the element's vertical position, by selecting the element and go to Edit / Element Settings / Relink Home Story. Then delete the wrong one if not needed.
