Sculptdesign
Change in level in structural slabs and raised floor areas
I work mainly in interior refurbishment and it is not uncommon to work with buildings which have changes in slab level or recessed/raised areas in the structural slab.
As part of interior fit outs there is also the possibility that I would want to introduce raised floor levels - for instance a few steps up to a platform seating area in a restaurant.
My question is how do I achieve this in ArchiCAD? I see tutorials on how to create holes but not recesses or raised sections. Currently I am layering smaller slabs on top of one another to achieve the correct levels.
A more complicated situation that I currently have is that there is a step in the structural slab which has a curved edge, where I want to show a straight edged raised floor over it, and it will not align with the existing slab below. Can I make the new raised floor slab fill the void underneath so in section it is shown correctly?
Thanks for the help.
Ash.
ArchiCAD 26 Solo - Mac
David Maudlin
SEO (Solid Element Operations) can be used to create recesses, look for it in the Help files. Another option is to use a Mesh rather than a Slab (for existing conditions), you can add points and lower/raise them as needed.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
