Strawbale23
Change project zero height
 Is there an easy way to relocate the level zero in a project?
I have a renovation project, the initial project zero has been redefined as the project advances and I would like to change it with out disrupting the model.
In other words I would like to reposition the project zero to the new finished floor level. so that all dimensions, window and door markers refer to this finish floor level. I have tried using the reference levels but that has too many set backs to be practical. I do not want the other story levels to change, just the project zero to reposition 5cm higher.
Hope this is clear.
Is there an easy way to do this??
thanks
AC26
https://www.zendsign.fr/
11 Replies 11
DGSketcher
Legend
Here you go... I have one Combination which holds multiple Rules - one for each Story. Each Rule only works on the 3D Elements and each is assigned a different surface colour from the paint section.
Strawbale23
thanks 👍
AC26
