Steve Hyde
Change single door swing on door with sidelight
I wish to change the hinge side of single door with with side light to swing in the opposite direction
1 Solution
CosminF
You can use the Door with sidelight on side 2 object and place it with the "outside" on the inside.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
4 Replies 4
CosminF
Steve Hyde
Appreciated CosminF.
vistasp
Mentor
Steve, you need to mark Cosmin's post as the accepted answer, not your own. 😉
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
I fixed that.
