‎2006-07-25 01:40 PM
‎2006-07-25 04:34 PM
‎2006-07-26 10:17 AM
‎2006-07-26 11:29 AM
nats wrote:Mostly I have to agree with you on this .... the default pens in many of Graphisofts library objects are all over the place. One of the fun jobs here is to go through all the objects we put into our library and tools in our template file and change the default pens when required.
Either way isnt is marvelous that nobody seems to know which pens are used for what?
What exactly is Graphsofts game here??!
All I know is when using the default pens the library parts come out really thick and look terrible which is bloody ridiculous.
Nats
‎2006-07-26 12:52 PM
‎2006-07-26 06:41 PM
recent wrote:how, please tell. i haven't found anything abouth this.
But you don't need to change the default pens
you can make a copy of the "Pens & Colors"
and then you can switch between them..
theres no need to change the default!
but that's what iäm thinking
‎2006-07-26 08:37 PM
how do you change the pens&colors settings without having to modify them individually and/or per-project?Pen colors and thicknesses are modified in the Documents>Pen Sets>Pens & Colors, and can be 'Stored As' a custom defined set. You can only modify a group of pens to either one color or thickness at a time. Otherwise for the most part, you typically modify one pen at a time (sorry). HOWEVER, once set up for one project (and it doesn't take long), using Options>Element Attributes>Attribute Manager you can 'Save As' or export the pen sets for use in other projects. Pretty straightforward. HTH
‎2006-07-26 09:59 PM
‎2006-07-27 12:16 AM
nats wrote:Graphisoft's game is to provide a flexible pen system.
Thanks but this topic has just confused me even more. The pens shown on this topics are nothing like the pen colours we have. perhaps the UK and american version is different?
Nats
‎2006-08-08 12:07 PM
owen wrote:I agree! I must admit only really using AC8 & 9, the new pen sets in 10 need getting used to. When i learnt ArchiCAD we were told by the training course not to change them as they can cause brain ache! So now they are different in 10, im back to square one. I hear that there is a new V10 pen set that replicates V9. But im still waiting for our pass word from our UAS dealer. Doh!nats wrote:Mostly I have to agree with you on this .... the default pens in many of Graphisofts library objects are all over the place. One of the fun jobs here is to go through all the objects we put into our library and tools in our template file and change the default pens when required.
Nats
One of my favourites are the 2D people in the AC9 library (not using the 10 one quite yet) ..... Pen 4 (0.35mm) is the defaultSo 2D outline people are given pen weight on par with a cut masonry wall ...
They look tops punching out on the set of otherwise fine lineweight elevations I just printed out
