Clean Wall Intersections between Slanted and Straight walls.
I have a wall that will be slanted outwards 120 deg., with its two end walls being staight 90 deg walls. How do I get the intersections to be correct, as they are with two 90 deg straight walls?
4 REPLIES 4
Here is a pic. I need the end of the straight wall to align perfectly to the edge of the angled wall.
Is there are way to do this without having to use the roof tool and trim to roof?
Can't you just Intersect them (Ctrl+I)?
Yes you can............just the answer I was looking for. I've never used that tool before ...........Thanks for the help!
Dwight
The presumption when using a tilted wall is that the side walls should extend to meet the TOP of the tilted wall and they will automatically get trimmed.
Dwight Atkinson
