Col Grid Not Visible in Section/Elevation Viewpoints - AC17
I'm having issues getting the column grid to appear in my elevation and section viewpoints. Sometimes when I create a section, the grid will appear in the view, but seems like most of the time it does not. I've gone through every setting in regards to the view and section settings, and haven't had any luck. I'm sure its user-error and probably something very simple, but maybe its a bug that I don't know how to fix. At first, it seemed like the only way to get the column grid to re-appear was to delete my section/elevation and redraw it entirely. But now, not even that is working. I'm about to lose my mind! Help!
Eduardo Rolon
Items to check:
1. If the Grid is outside of the section/elevation depth it will not show
2. If the grid is not perpendicular to the section/elevation it will not show
3. In the section/elevation settings check how the grid is setup, specially if you are specifying which grids are shown manually.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
