Column and Beam Display problem
We are running into an odd issue with columns in our project. It seems that there is something causing our columns to not show completely in the model. They only show part of the length of the column, even though the column extends all the way to the ground(pictured). It seems to have something to do with the beams that are intersecting them, since when i edit or delete one of the beams, the way the column displays changes (remains incorrect, just a different incorrect than before). I have checked to make sure there is nothing on a hidden layer that may be intersecting the columns, and that there are strange crops or solid element operations going on. Any idea why this is happening?
0 Replies 0
