2016-03-28
10:00 PM
2023-05-26
02:18 PM
Rubia Torres
2017-01-31 06:14 AM
dieselboy wrote:I know its been a while since this was posted, but I may have a solution which seems to have finally solved a similar issue I had.
I am having issues with getting views from my detail project onto sheets in my actual projects. There is no Teamwork involved.
I made a separate .PLN file for office standard details etc. so that I can "drag and drop" onto sheets in my other actual projects. However when I do this the standard detail doesn't load. It tries to update and never finished.
The drawing update window says communication error
Any Ideas?
relevant wrote:I only just stumbled across this solution, but I've tried opening the project and details in different order, leaving one open and restarting the other, etc... and the details plan is now shown as (active) when its running, as expected, and update is working just fine.
Cause:
One possible cause of this problem is an nVidia graphic card related application, called nVidia GeForce Experience. The application disturbs the Inter-process Communication (IPC) between the ArchiCAD instances. The memory being used up is the consequence of this disturbed connection between the two ArchiCAD instance.
Solution:
Stop and disable ‘NVIDIA Streamer Service’.
Steps:
- Launch the Computer Management by right clicking on ‘Computer’ (select ‘Manage’ from the drop-down menu) or you can also open it from command prompt or from Run (the run command for opening: compmgmt.msc)
- Double Click on ‘Services and Applications’
- Open ‘Services’
- Select ‘NVIDIA Streamer Service’ and open the Properties from the drop-down menu by right clicking on the service
- Click on ‘Stop’
- Change the Startup Type to ‘Disable’
- Apply the changes
