2021-04-19
		02:16 PM
		2023-05-09
		03:44 PM
			Rubia Torres
2021-04-22 04:20 AM
griggadee wrote:
Thanks Barry. Do you happen to know if there is a default origin for projects? It's strange how all of the materials line up to the exact same default origin, yet any new complex wall profiles seem to be referenced to a totally different origin point and even resetting this texture does nothing. It's not like I even chose an origin point originally. It's just whatever was set by the programme.
2021-04-22 05:31 AM
griggadee wrote:I don't understand the logic applied here, but it is indeed dependent on the width of the wall.
Thanks Barry. All layers are turned on and there are no walls under, over or near these walls affecting them in any way. It's very strange to say the least!
In terms of reference lines, having the reference line on the inside of the wall creates the problem. Having the reference line on the outside of the wall overcomes the problem. Whilst this appears to be a good thing, this of course is not a workable solution, because the entire model, across 4-storeys, is drawn with the reference line on the inside, and therefore I would have to redraw the entire perimeter on each floor just to suit that one problematic section, which is just not practical.
I created another video showing the different results for internal and external reference lines and also discovered another piece of the puzzle.It seems that wall thickness is what is causing the issue!The proposed wall is 480mm thick. When drawn at this thickness, the corner issue appears. If I reduce the wall thickness down to 350mm, the corner appears just fine! How utterly strange! Maybe you can test drawing the wall to the dimensions shown in the print screen under and see what results you get? Here is the video:
2021-04-25 03:23 PM
2021-04-27 07:09 PM
