Complex Profile Wall End Settings
I can't figure out where to change the wall end for one of the complex profile elements. Frame is supposed to be thicker than stone and it is, but the wall ends represent differently. Any ideas?
Thanks!
DGSketcher
Legend
See if this helps...
https://helpcenter.graphisoft.com/user-guide/76462/
This might also help...
https://helpcenter.graphisoft.com/user-guide/76458/
See the section on Components Panel
Check the settings of your Composite in the Composite Dialog.
Probably the Skin End Line for you Brick skin is set to that thick Pen.
Thanks! This helped.
