Complex Profile-lines not showing up
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-02-14 12:46 AM
Anyone have an idea of what I've done wrong? Note the soffit and trim are also done as a complex profile and there's no problems there.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-14 03:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-14 09:58 AM
check to see that you do not have two (or more) walls over each other, if you have duplicates they tend to overwrite each other.
regards,
Scott BT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-15 02:28 AM
Maybe ArchiCAD was just grumpy that I was making it work 6 hours of overtime because everything seems ok today.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-15 01:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-22 12:30 AM
I've updated my hardware configuration, not sure if that makes a difference. This is very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-22 08:53 AM
If you are just having this problem with a couple of walls then this approach might work for you, if this is happening with all your walls, then I don't know what to tell you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-22 05:38 PM
Sadly, I have given up, switched the section status to 'drawing' and have drawn the lines in manually.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-22 07:55 PM
One comment Jere, you don't need to switch to drawing just to add the lines. You can keep the model connected and just draw the lines in. That way the section stays accurate and worst case the lines are wrong.
M1 Macbook Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-25 04:17 PM
