Complex Profile materials
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-06-30
05:34 AM
‎2023-05-26
12:41 PM
Rubia Torres
Ever since beginning to use Complex profiles (v.10?) I've wanted to have this level of control, but found it's impossible - short of duplicating a separate complex profile for each material. Tedious and cumbersome to say the least!
Is it possible, now that we've reached v.15 (well, almost!) or will it go on "Santa's Wish List"?
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-30 07:54 AM
Is this what you mean?
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-30 08:23 AM
If you need different materials for individaul elements using the same complex profile you will need to duplicate it.
Just trying to think outside the square I guess you could use the shell tool (extruded and detailed profile) for RHS and SHS beams and columns, but then you wouldn't really have a beam or a column.
You can set the materials for these individually but you will need to define the profile for each beam every time you want it or copy and paste the original.
Also no good for "I" and "T" beams ("L"'s will work).
Gives you other advantages though as you can rotate the shell in any direction and you can also set the end angles of the shell for vertical mitres.
But they won't automatically mitre in plan like beams.
I would say though to forget shells as a complex beam substitute.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-30 11:54 AM
Rod wrote:Thanks for taking the time to answer Rod, but no this isn't what I mean.
Gerald, not quite sure what you are after. But see attached.
Barry Kelly seems to have answered the question, at least for now:
Barry wrote:Would you both mind casting a poll vote for this feature if you think it should be included please.
Same goes for anyone else who may post a reply here.
I'll add this to the 'ArchiCAD Wishes' section too
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-30 03:11 PM
Barry is correct, duplicate is the only way.
The end of the beam material is all that you can change,
all sides are greyed out
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-30 04:36 PM
here's the basics:
make a complex profile
assign it to a beam/wall/column (let's say a beam)
select the beam, right click, select capture profile
make the material change
click apply to selection.
don't store the complex profile
I don't advocate doing this. I never like seeing anything custom (whether complex profile, layer combination, model view options, etc.), but it's a solution.
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-01 04:11 AM
What Jared suggested works.
He has simply made a duplicate but not given it a name.
I am not sure if you ever did save one of those "custom" profiles would all the other custom profiles change?
Would have to test this.
Like Jared said, anything "custom" is risky.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-01 10:07 AM
Be very careful using custom profiles for 2 reasons
1 its become unmanageable
2 you can't globally change the profile of the profile and maintain the materials
you can't build a line
Mac Studio
iPad Pro
iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-01 04:54 PM
And like all of us are saying, having a one off custom profile is okay, sort of. But it's very bad practice to use custom profiles all over the place. I only originally mentioned if for purely academic purposes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-02 02:10 AM
Is this what you were looking for?
Snap
