2010-05-05
03:49 PM
- last edited on
2025-07-22
12:22 PM
by
Aruzhan Hamar
2010-05-05 07:57 PM
Matthew wrote:Ok, so when drawing a foundation wall that you'd like to use in multiple projects, you should make it small (in height) knowing that you can always stretch it larger, correct?
Also remember that the wall won't stretch to be smaller than it is drawn in the profile editor.
2010-05-05 08:07 PM
Steven wrote:Yes. Always make adjustable profiles the smallest they will need to be.Matthew wrote:Ok, so when drawing a foundation wall that you'd like to use in multiple projects, you should make it small (in height) knowing that you can always stretch it larger, correct?
2010-05-05 08:12 PM
2010-05-05 08:29 PM
Steven wrote:Yes. The stemwall will stretch leaving the footing the same. In your other screen shot it looks like you may not have hotspots placed at the lower stretch line. This could cause problems.
2 unanswered questions...
1. Are the vertical stretch lines on my first post at the right location?
2. Can you stretch vertically in section?Walls no. Beams yes.
2010-05-05 10:49 PM
2010-05-06 12:21 AM
2010-05-06 12:23 AM
2010-05-06 02:33 PM
