2015-06-30 04:18 AM - last edited on 2023-05-26 02:57 PM by Rubia Torres
2015-06-30 05:33 AM
2015-06-30 05:36 AM
2015-06-30 05:39 AM
2015-06-30 05:41 AM
2015-06-30 08:14 AM
2015-06-30 08:30 AM
2015-07-02 09:49 AM
Barry wrote:Wow, thanks again. Yes I did have old file I brought into 18.
If you have an old file open in 17 or 18 you will find 'Legacy' mode will be ON by default so the surface overrides in the wall settings will not be available.
All you can do is apply a surface to the entire ends of the walls.
Legacy mode can be found in OPTIONS menu > Project Preferences > Legacy
If it is a new file that was started with a 17 or 18 template then the Legacy mode should be OFF by default and you will have the end ad side surface overrides.
