2025-12-15 08:42 PM - edited 2025-12-15 08:50 PM
I have modelled cavity wall constructions using complex profiles so that I can model in the brick coursing heights. I am finding that any doors or windows that I placed in the walls has no visible break line in the external leaf. The internal linings are fine however.
There may be a simple solution, but I cannot figure this out. Does anyone have any idea what I am missing?
Solved! Go to Solution.
2025-12-17 08:35 AM
You won't see the 2d lines of a complex in the section or on plan only the contour attached to files.
Make sure every fill has an outline in the complex profile. Select all the fills and add the outline.
2025-12-16 02:07 AM
Screenshot?
Do you have Outlines turned off for any of your CP wall parts? Not sure if that does anything...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2025-12-17 08:35 AM
2025-12-17 10:35 AM
Many thanks.
2025-12-18 02:06 AM
You can also select specific fill edges to toggle outlines on them seperately.
